67Monaco
Oh I like the wheels, I'm a custom wheel guy, but not on your car. Another ride or even color they'd be great.
View attachment 36069View attachment 36070View attachment 36071View attachment 36072View attachment 36073View attachment 36074View attachment 36075View attachment 36076View attachment 36077View attachment 36078
So I am getting real close to the completion of the '68 Polara, and upon it's completion I would like to find her a new home. This is where the honest opinion part comes into play. From reading a lot of threads, I can see that most of you have been in the C Body/ Mopar game for a while. Now if ya'll could imagine you built this car, or saw this car for sale, what would be a fair selling price?
Here is a mostly complete list of the work done.
Thanks all!!
Original paint with a few dents and dings, but it shines. ALL of its exterior trim is there, it shines too. All gauges and lights work. Two rust holes on the trunk floor, about dime sized.
Under hood: 383 c.i.
Complete disassembly, honed cylinders
New: piston rings
main bearings
rod bearings
oil pump
Summit Racing camshaft and hydraulic lifters
brass freeze plugs
all seals and gaskets
aluminum water pump housing
water pump
alternator
electronic voltage regulator
power steering pump
electronic distributor and control unit
Sanden A/C compressor, condenser, and all under hood components to properly convert to R134
Weiand four barrel intake
fuel pump
fan clutch
aluminum 3 row radiator
spark plugs and wires
all hoses and belts
Miscellaneous new parts:
3in side exit exhaust (IT IS LOUD)
gas tank & sending unit
in dash A/C and heater control vacuum switch
drive line u-joints
reupholstered front and rear bench seats
dash pads and sail panels recovered
Wheels- 17x7 & 17x9.5 Wrapped in Nitto 555 tires 235/45 17 & 275/40 17
lots of new hardware
KYB Gas-a-Just shocks on all four corners
Addco rear sway bar
front suspension bushings, ball joints, and wheel bearings
front disc brake conversion with all new brake components
heater core
walnut trim steering wheel
Dynamat, carpet & headliner
Work to still be done:
replace windshield
miscellaneous bits and pieces
I'm going to pass on guessing at a value, but make two observations on your pictures. First if you assembled the headers without removing the paint from the mating faces on the heads, you're going to have exhaust leaks much sooner than later. Paint makes a terrible sealing surface. Second, nice job on the exhaust system, but if you don't lengthen those shorty tail pipes, you're soon going to have no rocker panels in front of the rear wheels.
I do not like the wheels and if you have the originals I would rather put those on as most people wouldn't want the other wheels in my opinion.
The seats are not original anymore.
I would say in the ballpark of 6k.
Here is a 68 Polara 500 for sale in california, 383 HP car in comparison, it has buckets and console and a great colour for 6.300$ just to get an idear.
http://losangeles.craigslist.org/lac/cto/4601659489.html
Pfffffffttttttttt.Me thinks judging by what he's done so far he's upside down..
If he says "absolutely", then be kind to him.You DO know you're upside on that car regardless of what you say or think...
So, what do you think so far, Scotty?
Me thinks judging by what he's done so far he's upside down. I'm gunna say by about 5K. Just a guess. And since I'm in a better mood today, and not on my phone after putting out fire in the garage, the wheels are fine, they can be changed. I think the thing that gets me is the sidewall of the tire. They need more to fill the wheel well better. Other than that it looks like a decent ride. And the engine detail is great. I hope to get to that level someday.
