Some more classic pictures
Yah, that was dumb. Was grasping.
It would be hard to inspect anything while wearing these...
Some speculation here.... Since GM was using lacquer paint back then, the paint would be dry before assembly. So it wouldn't be part of the process (obviously).
It makes me wonder if it was after touch up of the finished car. They do inspect and pull cars off the line to repair flaws in paint .
You're right. It's either a publicity photo where someone was dumber than **** or it may be a Final Inspection booth.
Or maybe there is a final rinse and dry in the process.
Final Repair oven.
Low temp infra-red lamps due to the plastic, vinyl etc in an assembled car.
While I wasn’t in the business in 57, the only place I’ve ever seen a fully assembled vehicle in an oven is in final repair. This looks like an IR oven with some agitation air ducts down the sides and top. Every plant has a final repair paint line. Usually just a forced air oven but have seen IR lamps.
