Speaking of exhaust.......
:sSig_thanks: for the link. Ill have to dig up some part numbers and exercise my search skills.
Since you can't see the casting numbers clearly, I reached out to YearOne today. Here's their reply:
HP689LH (Drivers Side)
INFO 17 (I) TECH INFORMATION
INFO 18 (I) Includes casting number 2843992 and pentastar as original.
INFO 19 (I) Pentastar is cast upside down as original.
HP689RH (Passenger Side)
INFO 18 (I) Includes casting number 2806900 and pentastar as original.
According to the Mymopar.com casting numbers page, those are '68-'69 Magnum castings. Anyone know if they work on '67s? Did they change castings for performance or for fit?
ds c body manifold is not same as a b body. ps is same as a b body
Good point. I see a different casting number for regular C body manifolds but not for Magnum manifolds. Do those get different castings as well?
On another (related) topic, I talked to a guy about doing a run of these. Best case, you could break even with 25 sets, but it could also be 60 sets. That would mean you're out somewhere between $30k and $72k, and you wouldn't even make a nickel in that case.
No wonder the manifolds are marked "not eligible for discount" on the website!
