REBELLE 300
Hey guys need some help whit my dash lighting I have no lights the map light switched bulb works but no instrument cluster light like the speedo , the clock and some other. the green cold light works. i changed the dimmer switch module I change the fuse under for instruments my next speed is to change the bulbs but that's a bigger job so is there any other diagnostic I can make or something else I should check before I remove the hole instrument cluster to try changing the bulbs thanks for all the info you guys can provide
Antoine
Antoine
