Samplingman
Ok, moment off truth will be happening next or so, provided my body stops breaking down, lol.
First, what is the bare-minimum wiring that has to be in place to run the engine for cam break-in? Do I need the column hooked up if I use a remote starter? Could I just bypass the bulkhead connector?
Trans is rebuilt, is is necessary to have the kick-down linkage set up first? I know I have to add fluid after the engine starts so the pump doesn't burn out.
Carb is rebuilt, how do you get that adjusted while trying to fire the engine while adding more fluid to the trans, while making sure coolant is flowing and also not trying to die?
Am I over-thinking this whole operation?
Any step-by step advice would be greatly appreciated!
James
James
