Steering column questions
BLIMP
Illinois
So my 72 Monaco has a standard column, but I have a tilt column from a "73 Dodge" that I intend to swap in. Before I start dissasembly, I have a few questions.
Am I correct in believing that both the ignition lock and turn signal cams are different between the two?
The actual cruise control knobs on the end of the tilt column are damaged, will the actual stalk transfer? Or maybe I could disassemble the damaged parts and get creative with some epoxy...story of my life but I'd hate to just throw it in the trash.
The cruise switch may be the same, but the ignition and turn signal switches are different. There may be an adapter harness for the ignition switch you will need also.
