Stargazer
Wow that definitly helps Samplingman! Nothing better than to see, instead of just reading about it. Thanks for these photo´s. So spline differences are not really a issue between 69, 70 or 71´s. Column and wheel width visually could be a thing.Perhaps a photo essay will help on the differences. All non-tilt column shafts have the same spline size, 1969 to 1973, so no problem fitting there. As for the steering wheel base, ‘69 - ‘70 are close, ’69 is smaller by 1/2 an inch
69 on the left, 70 on the right
1970
1969
69 column and wheel fit.
Here is the 1970 mated with the 69 column, as you can see it is wider than the column.
The horn ring would hide the differences for the most part.
Here is the wheel from a ‘73, very similar to the ‘71. Note that the horn mechanism is quite different than the ‘69-70, it will look odd, but functionally would mount without a problem.
View attachment 510320View attachment 510321View attachment 510322
Hope that helps.
Another thing, these old wheels all seem to have many large cracks. Off course these can be repaired. But, I saw this "wheelcover", not sure what it's called in English. Could that be a solution for camouflaging the cracks? Plus. I like the feel of one. Are these still availible?
