polara10x500
Can anyone else just reach in their 69 flip SL switch on at the panel with no key, car off and have SL come on provided the floor dimmer is on low beam and headlight switch still in off position?
I dont know how the 69's are wired, but for the 70's the super light should only be able to come on with the headlight switch turned on, superlite switch on and the dimmer switch in the "high beam" position.Can anyone else just reach in their 69 flip SL switch on at the panel with no key, car off and have SL come on provided the floor dimmer is on low beam and headlight switch still in off position?
Low beams, idling at 750:
Low beam with superlite on, idling at 750:
So I was finally able to finish up the lighting upgrade on the polara. It involved getting a custom headlight harness made by Rob Yule that included a third relay to run the superlite directly off of the alternator. I used headlights spec'd out by @slantsixdan at Daniel Stern Lighting. I also followed his tech tip on how to aim headlights here, and used this article on how to aim the superlite:
It worked out really well!! I have done some night driving and the light is pretty useful. I have not done much highway stuff with it but will in the next couple weeks. here are some pictures with the superlite on and off at the end of my street:
On
off:
again this is with the bulb that @slantsixdan had made. I provided a link in post 84. But if that link gets broken I believe you just take a good H3 bulb, remove it from its base and place into the superlite bulb's base. you move that bulb further out and in the base to get the proper focal length. For future reference if anyone actually tries this the beam should be able 8 inches high when the car is 25 ft from a wall.
"a specific grille insert" is misleading language in the article. For 1970 the plastic left grill piece comes molded with a hole for the light assembly with its own part #. Also not specifically mentioned in the article is that the mounting hardware for 69 and 70 does not interchange.I don't think I have seen this 2012 article on the superlite. Note the (Michigan-based T-code, if it is the car that I think it is) EB7 1970 Polara 'vert in the photo:
Let There Be More Light
Shedding Light on Dodge’s Super-Lite! In a recent story about the junkyard discovery of a 1969 Dodge Polara 500 convertible, we stumbled onto somet...www.dodgegarage.com
