wyldebill
Lowered the back glass on my 67 t&c this evening, and can't get it to raise. Either from the front or the gate switch. With the glass down, can I gain access to the motor? Any help would be appreciated.
Making the window raise when the tailgate is down will likely break the glass unless you are supporting it in some way! not sure what kind of jumper wire you rigged so thought i would caution you about that.Found the culprit. The safety switch is on the passenger side on this car. Cleaned with contact cleaner. Still wouldn't work. Built a jumper wire. That will stay until I find a replacement. Thanks for the help
