57fury440
Does the Yellow Teflon tape work for gas lines and fittings? It says for natural gas on the package. Thanks in advance.
Agree. Don't use on fuel line. Heck - I never use it anymore on anything. Only a teflon sealant such as this one. I use a Loctite version - 567.Don't use it on gas lines. The little shards can get in the needle and seat and cause all sorts of havoc.
Permatex makes a great Teflon thread sealant that works great for that application.
Those HP Carter fuel pumps use an NPT to flare fitting. I've used them a few times myself as have many others. Some of the 50's fuel pumps have that NPT fitting too. Then there's any add-on electric pumps and even a few fuel filters too.i cant think of anything on the fuel system of our cars that uses pipe thread
Not sure what kind of fitting those are. But if they are a npt style thread use the teflon style sealant. If you are referring to the flared fitting, nothing goes on them.Should it be used or NOT used on pressure hoses like Power Steering pump to box fittings?
Seems like the old-line techs would use the #2 Permatex to put a hin coat around the edges. Probably for lubricant and ease of installation than "dry"?What kind of sealer on Engine block Drain plugs ?
No sealer. The washer is the sealer.What kind of sealer on Engine block Drain plugs ?
I assume you mean the coolant drain plugs that go into the water jacket. That Teflon sealant I mentioned would work great and so would #2 Permatex.What kind of sealer on Engine block Drain plugs ?
I think you are referring to the oil pan drain plug, which does seal with the washer, and not the block coolant plugs.No sealer. The washer is the sealer.
The threads on an oil drain plug are straight threads, commonly 1/2x20 from mid 60's on up. So the threads will leak by design. The sealing is done by the washer between the drain plug head and the oil pan.IF you have a leak through the threads of the oil pan drain plug, you need a new drain plug. Some auto supplies have "oversize" drain plugs for worn threads on the oil pan internal nut.
