1973 Dodge Monaco.
I took the Big John approach today, mostly because I would rarely use the $60 tool and I wanted to try a fiber pan gasket.
Shift Shaft Seal, National 8609
· Recess or indent for seal mount: finish cleaning with rags, small flat blade screwdriver, pick
· National Seal 8609, Federal Mogul, made in USA: Dynatex transmission grease, lubricate seal and pack between seal and metal housing. Also lubricate recess.
National on right
· Seal tool: bolt 3/8 thread 1.75 inch length, upper washer 1.375 inch diameter, lower washer 1.5 inch diameter, nut 5/8 inch. 9/16 inch wrench on bolt head, 5/8 inch long socket, 3 inch extension, 3/8 ratchet on nut. Scratched fry pans make good trays
· Process: place seal in recess. Assure upper washer is centered on top of seal. Hold bolt head still with 9/16 inch wrench, while tightening nut to firm resistance. Top of seal is flush with housing of transmission.
Valve Body
· Valve Body Install: Dynatex onshift shaft. Push shaft through the seal, while assuring that accumulator spring stays upright and also assuring that park rod goes into park rod seat. If the transmission was on the bench, I’d turn output shaft until parking rod seats, but because it is in the vehicle, turning the driveshaft back and forth is required for it to fully seat. It seats on the curved lip visible in the picture and the metal block above the lip has to go up for it to fully seat. Install valve body: 10 bolts, 100”lbs, 7/16 ss, 6ext, adapter, 3/8 torque wrench. To test if you have the park rod fully seated, if you can get your hand on the rod, it should not go forward without starting to lift up although it does have a little play to the rear. Also with the shift lever in the park position, all the way to the rear, and an assistant holding one tire, trying to turn the opposite tire. It should not turn the driveshaft. If you have the car in neutral, for instance, the same test will turn the driveshaft.
Ball at end of park rod seats here
Park rod after valve body installed. Very hard to see whether seated correctly
Valve body. 40 miles on filter so I reused it.
