Thread for Craigslist morons
could be a cuban rebuild
New motor, transmission, brakes, suspension bla bla:
Need to sell in order to have a "more reliable car to commute" with...
This is a worthwhile laugh...
1965 Chrysler 300 - $11000
Hi folks,
I am selling a 1965 Chrysler 300. This car only had 1 owner who recently passed. Below are a few highlights:
- 17k original miles
- single owner
- new tires
- runs great
- great original interior
The car does need a new front bumper and I don't have the time to swap it. It's a very easy fix.
If you have questions, feel free to call or text me at 510-453-8821 or email me at ronsoteloc@gmail.com.
No low ballers, and serious inquiries only.
Thanks,
Ron
Apparently "Moron" in French is Smart Marketer....
Translated from da French version eh?
Beaucoup D'argent.....$18000???
Chrysler 300 1966 très bon état | voitures d'époque | Gaspésie | Kijiji
Vehicle that always works very well. Some addicts in the benches, painting and roofing. Comes with original spindle tires. Transmission to the floor. Original electric group, original 8-track radio (comes with some cassettes). For older car enthusiasts
Well at least you get a spare(s)
1959 Plymouth furry 2dr. Hardtop
It was not the same without the text...
"59 Plymouth furry for sale. This car had thousands of dollars put into it towards auto body restoration at a professional shop. It was media blasted to bare metal, treated the rust, welded in new sheet metal and all body work is completed except the hood, trunk and one quitter panel. Car is complete with all glass, trim ,bumpers, interior ext. car does run and is in primer. Asking $9,000 but will take a serious offer. No emails please. Also I have before and after pictures on hand. Thanks La
rry show contact info"
La
rry seems to need keyboarding help, the rest is unfixable.
I typed in "mopar steering box". This is what I got.
Performance Parts Sale
Sale!! Mustang,Camaro,Corvette,Challenger Charger & more...CALL OR STOP IN FOR SALE PRICES***
We handle everything from air filters to Superchargers and Turbo Installs.
Exhaust systems from Magnaflow,Borla,Corsa,Flowmaster& more... ComputerChips/Programmers SCT,Superchips...
Suspension and Chassis parts and insatllation and tuning
Ring&pinion Gear installs
TRUCK ACCESSORIES
PRO FAB PERFORMANCE PLUS
7827 CLARK MOODY BLVD
PORT RICHEY,FL 34668
727-849-9300
key words
Mickey Thompson Tires, Mickey Thompson Wheels, Moser, Motive Gear, Performance Accessories, PIAA, Pilot, Putco,, Rancho, Ratech, Ready Lift, Richmond Gear, Skyjacker Suspension, Suncoast Hoods, Super Chips, Superlift, Suspension Techniques, Trux-Stuff, Valley Industries, Ventshade Company, Warn Winch, Westin, Airaid, Airlift, Auburn, Bell Tech, Bestop, Blower Drive Service, Bull Dog Winches, Bully Dog, Bushwacker, Carriage Works, DeeZee, DiabloSport, Edge Products, Energy Suspension, Extang, Fab-Tech, Firestone Industrial Products, Ground Force, Hellwig, Husky Liners, Hypertech, K & N, K.C. Hi-Lites, Lund Industries,
-KEYWORDS- BELOW- Air & Fuel Delivery , Books/Videos/Software , Brake Systems , Chassis & Suspension , Collectables & Apparel , Cooling & Heating Drivetrain , Engines & Components , Exhaust , Exterior & Accessories , Fasteners & Hardware , Fittings & Hoses , Gaskets & Seals Gauges & Accessories , Ignitions & Electrical , Interior & Accessories , Marine , Mobile Electronics , Oils, Fluids & Sealer , Outdoor & Recreation , Paints & Finishing Safety Equipment , Tools & Shop Equipment , Trailer/Towing/Winches , Wheels & Tires , Air Box Intake Restrictors , Air Box Lids, Air Cleaner Assembly Retaining Clips, Air Cleaner Bottoms, Air Cleaner Gaskets, Air Cleaner Inserts, Air Cleaner Replacement Components, Air Cleaner Studs, Air Cleaner Tops, Air Cleaners, Air Filter Assembly Adapters, Air Filter Assembly Spacers, Air Filter Boxes, Air Filter Elements, Air Intake Bypass Valves, Air Intake Kits, Air Intake Mounting Brackets, , Air Intake Tube Adapters, Air Intake Tube Inserts, Air Intake Tubes, Air Intake Velocity Funnels, AN to Straight Cut O-Ring Fittings, Bell Cranks and Kits, Belt Drive Fuel Pump Pulleys, Blow Off Valve Lube, Blow-Off Valve Adapters, Blow-Off Valve Components, Blow-Off Valve Filters, Blow-Off Valve Return Hoses, Blow-Off Valve Springs, Blow-Off Valves, Boost Bypass Kits, Boost Controller Components, Boost Controllers, Boost Fuel Cut Adjusters, Cabin Air Filter Elements, Cable Ends, Carburetor Accelerator Pump Arms, Carburetor Accelerator Pump, Carburetor Adapters, Carburetor Air Bleed Kits, Carburetor Air Bleeds, Carburetor and Calibration Kit Combos, Carburetor and Fuel Pump Combos, Carburetor Boosters, Carburetor Calibration Kits, Carburetor Cruise Control Brackets, Carburetor Dashpots, Carburetor Discharge Check Needles, Carburetor Discharge Nozzle Gaskets, Carburetor Discharge Nozzle Kits, Carburetor Discharge Nozzle Screws, Carburetor Discharge Nozzles, Carburetor Dust Covers, Carburetor Feed Lines, Carburetor Float Hangers, Carburetor Float Pins, Carburetor Float Springs, Carburetor Floats, Carburetor Fuel Bowl Extensions, Carburetor Fuel Bowl Gaskets, Carburetor Fuel Bowl Screw Gaskets, Carburetor Fuel Bowl Screws, Carburetor Fuel Bowl Sight Plugs, Carburetor Fuel Bowl Vent Screens, Carburetor Fuel Bowls, Carburetor Jet Kits, Carburetor Jet Service Pack Combos, Carburetor Jets, Carburetor Linkage Bushings, Carburetor Linkage Kits, Carburetor Main Bodies, Carburetor Metering Block Conversion Kits, Carburetor Metering Block Gaskets, Carburetor Metering Block Main Well Plugs, Carburetor Metering Block Metering Valves, Carburetor Metering Blocks, Externally Adjustable, Carburetor Metering Blocks, Replacement, Carburetor Metering Plates, Carburetor Metering Rod Hangers, Carburetor Metering Rods, Carburetor Needle and Seat Gaskets, Carburetor Needle and Seat Hardware Kits, Carburetor Needle and Seats, Carburetor Power Valve Block-Off Plugs, Carburetor Power Valve Gaskets, Carburetor Power Valve Restrictors, Carburetor Power Valve Savers, Carburetor Power Valves, Carburetor Rebuild Kits, Carburetor Replacement Tops, Carburetor Throttle Body Gaskets, Carburetor Transfer Tube O-Rings, Carburetor Transfer Tubes, Carburetor Upgrade Combos, Carburetor Vacuum Secondary Adjustment Switches, Carburetor Vacuum Secondary Covers, Carburetor Vacuum Secondary Diaphragms, Carburetor Vacuum Secondary Housing Gaskets, Carburetor Vacuum Secondary Kits, Carburetor Vacuum Secondary Springs, Carburetor Velocity Stacks, Carburetor Vent Tube Baffles, Carburetor Vent Tubes, Carburetor Wedge Plates, Carburetors, Charge Motion Control Valve Delete Plates, Charge Motion Control Valve Delete Plugs, Choke Block-Off Plates, Choke Cable Brackets, Choke Cables, Choke Kit Components, Choke Kits, Choke Tubes, CO2 Bottle Nuts, CO2 Cooling Air Intakes, CO2 Cooling Bottles, CO2 Cooling Fuel Bars, CO2 Cooling System Replacement Components, CO2 Cooling Systems, CO2 Intercooler Sprayers, CO2 Purge Kits, Cold Start Valve Plug Kit, Counting Cars Combos, Coupler Fittings, Crankcase Breathers, Crankshaft Pulleys, Crush Washers, Diesel Banjo Bolt Upgrade Kits, Diesel Cool Down Timer LED Alarm Kits, Diesel Cool Down Timers, Diesel Engine Air Shutdown Valves, Diesel Fuel Heaters, Diesel Fuel Injector Nozzles, Diesel Fuel Pump Driver Coolers, Diesel Fuel Pump Driver Resistors, Diesel Fuel Pump Drivers, Diesel Governor Controllers, Diesel Governor Springs, Discharge Tubes, Distributor Check Valves, EGR Adapters, EGR Block-Off Plates, Engine Management System Components, Engine Management Systems, Engine Position Module, Exhaust Clamp Replacement Parts, Exhaust Clamps, Exhaust Crossover Plugs, Factory Five Mk4 Roadster Combos, Fans, Electric, Flame Arrestor Vent Tubes, Flame Arrestors, Floor Mount Throttle Linkage Systems, Fluid Cooler Installation Kits, Fluid Filter Components, Fluid Filter Mounting Brackets, Fuel Catalysts, Fuel Cell Bladders, Fuel .
Cell Cap Gaskets, Fuel Cell Caps, Fuel Cell Container Fill Plates, Fuel Cell Containers, Fuel Cell Desiccant Driers, Fuel Cell Displacement Components, Fuel Cell Fill Plates, Fuel Cell Filler Gaskets, Fuel Cell Filler Kit, Fuel Cell Filler Necks, Fuel Cell Filler Valve Components, Fuel Cell Filler Valves, Fuel Cell Foam Inserts, Fuel Cell Mounts, Fuel Cell Pick Up Hose Kits, Fuel Cell Pickups, Fuel Cell Quick Fill Spout Receptacles, Fuel Cell Split Nut Rings, Fuel Cell Tip Over Valves , Fuel Cell Vent Valves, Fuel Cells, Fuel Coolers, Fuel Distribution Blocks, Fuel Doors, Fuel Filter Elements, Replacement, Fuel Filter Mounting Brackets, Fuel Filter Replacement Parts, Fuel Filters, Fuel Injection Auxillary Injector Driver Kits, Fuel Injection Closed Loop Kits, Fuel Injection Over Run Cutoff Valves, Fuel Injection Sensor Kits, Fuel Injection System Components, Fuel Injection System Dual Tank Fuel Pump Kit, Fuel Injection System Wiring Harnesses, Fuel Injection Systems, Fuel Injection Upgrade Kits, Fuel Injector Adapter Harnesses, Fuel Injector Brackets, Fuel Injector Mounts and Bungs, Fuel Injector O-Rings , Fuel Injector Pintle Caps, Fuel Injector Retaining Clips, Fuel Injector Spacers, Fuel Injectors, Fuel Management Unit Calibration Kits, Fuel Management Units, Fuel Pressure Regulator Manifolds, Fuel Pressure Regulator Mounts , Fuel Pressure Regulator Rebuild Components, Fuel Pressure Regulator Rebuild Kits, Fuel Pressure Regulators, Fuel Pressure Safety Switches, Fuel Pressure Sensor Adapters, Fuel Pump and Regulator Combos , Fuel Pump Block-Off Plates, Intake Manifold Adapter Kit, Intake Manifold and Carburetor Combos, Intake Manifold Bolts, Intake Manifold Combos, Intake Manifold Cover Plates, Intake Manifold Inserts, Intake Manifold Installation Kits, Intake Manifold Lifter Valley Coolant Plates, Intake Manifold PCV Oil Baffles, Intake Manifold Plenum Dividers, Intake Manifold Plenum Spacers, Intake Manifold Runner Control Valves, Intake Manifold Runners, Intake Manifold Spacer Replacement Components, Intake Manifold Spacers, Intake Manifold Stud Kits, Intake Manifold, Carburetor and Camshaft Kits, Intake Manifolds, Carbureted , Intake Manifolds, Fuel Injected, Intake Manifolds, Fuel Injected Components, Intake Manifolds, Supercharger, Intake Manifolds, Top Sections, Intake Manifolds, Tunnel Ram Bottoms, Intake Manifolds, Tunnel Ram Tops, Mirrors, Modular Intake Tubes, Multipurpose Spring Assortments, Nitrous Nozzle Adapter Bushings, Nitrous Nozzle Mount Kits, Nitrous Oxide Accessory Kits, Nitrous Oxide Activation Switches, Nitrous Oxide Blow Down Tubes, Nitrous Oxide Bottle Blankets, Nitrous Oxide Bottle Bracket Mounting Rails, Nitrous Oxide Bottle Brackets, Nitrous Oxide Bottle Heater Controllers, Nitrous Oxide Bottle Heater Thermostat, Nitrous Oxide Bottle
Heaters, Nitrous Oxide Bottle Nipples, Nitrous Oxide Bottle Nut Washers, Nitrous Oxide Bottle Nuts, Nitrous Oxide Bottle O-Rings, Nitrous Oxide Bottle Roll Bar Mount Brackets, Nitrous Oxide Bottle Valve Openers, Nitrous Oxide Bottle Valve Replacement Components, Nitrous Oxide Bottle Valves, Nitrous Oxide Bottles, Nitrous Oxide Controllers, Nitrous Oxide Cooling System Replacement Parts, Nitrous Oxide Cooling Systems, Nitrous Oxide Distribution Blocks, Nitrous Oxide Filters, Nitrous Oxide Fuel Enrichment Systems, Nitrous Oxide Fuel Filter Fittings, Nitrous Oxide High Flow Tee Valve, Nitrous Oxide Jet Holders, Nitrous Oxide Jet Master Drill Bit Kits, Nitrous Oxide Jets, Nitrous Oxide Manifold Fittings, Nitrous Oxide Nozzles, Nitrous Oxide Plates, Nitrous Oxide Plumbing Kits, Nitrous Oxide Purge Kit Replacement Components, Nitrous Oxide Purge Kits, Nitrous Oxide Purge Lights, Nitrous Oxide Refill Station Accessories, Nitrous Oxide Refill Station Rebuild Kits, Nitrous Oxide Refill Stations, Nitrous Oxide Regulators, Nitrous Oxide Safety Blow-Off Discs, Nitrous Oxide Solenoid Mounting Brackets, Nitrous Oxide Solenoid Rebuild Kits, Nitrous Oxide Solenoid Replacement Parts, Nitrous Oxide Solenoids, nitrous Oxide System Wiring Kits, Nitrous Oxide Systems, Nitrous Oxide Top Shot Module Kits, Nitrous Solenoid Wrenches, Nuts, Oil Pressure Power Steering Brackets, Pressure Relief Valves, Pulley Spacers, Secondary Linkage Kits, Superchargers, Throttle Bodies, throttle Cables, Throttle Lever Adapters, Throttle Lever Studs, Throttle Linkage, Utility Jug Caps, Utility Jugs, Water Pump Fasteners, Water Separator Valves, ABS Hydraulic Valves, ABS Pumps and Motors, Accessory Drive Pulleys, Brake Rotors, Brake Shoes, Clutch Master Cylinders, Cooling Duct Hose, Counting Cars Combos, Diesel Engine Exhaust Brake Replacement Components, Diesel Engine Exhaust Brake Switch Kits, Diesel Engine Exhaust Brakes, Disc Brake Backing Plates, Disc Brake Kits, Line Locks,, Residual Pressure Valves, Shifter Replacement Parts, Automatic Transmission, Shut-Off Valves, Starter Rebuild Parts, Vacuum Pumps, Body Lift Kit Components, Body Lift Kits, Coil-Over Kits, Coil-Over Shocks and Struts, Lowering Springs, Motor Plates, Motor Torque Limiters, Racing Springs, Rack and Pinions, Rod Ends, Roll Bar Clamps, Roll Bar Components, Roll Bar Gussets, Roll Bars, Competition, Rolled Plastic, Seat Supports, Shackle Bushings, Shocks and Struts, Steering Boxes, Sway Bars, Swing Arms, Track Bars, Wheel Tubs, Wheelie Bars, Air Conditioning Compressors, Air Conditioning Kits, Alternator Brackets, Blower Motors, Electric Fan, Electric Water Pump Combos, Fans, Electric, Fans, Mechanical, Radiators, Clutch Kits, Flexplates, Flywheels, Manual Transmissions, Ring and Pinion, Ring and Pinion Gears, Shifter Brackets, Shifter Sticks, Automatic Transmission, Shifter Sticks, Manual Transmission, Shifters, Air, Shifters, Automatic Transmission, Shifters, Electric, Shifters, Manual Transmission, Torque Converters, Camshaft and Lifter Kits , Camshaft Block Protector Kits, Camshafts, Connecting Rods, Crankshafts, Crate Engines, Cylinder Heads, Engine Rotating Kits, Harmonic Balancers, Oil Pumps, Oil Tanks, Overflow and Recovery Tanks, Overflow Tank Components, Piston Rings, Pistons, Rocker Arm Studs, Rocker Arms, Rod Bearings, Rod Ends, Short Block Engines, Timing Chain and Gear Sets, Vacuum Pumps, Valve Cover, Valve Guides, Valve Locks, Valve Seats, Exhaust Wrap, Mufflers, Performance Packages, Air Vent Scoops, Automated Truck Step.
Aerospace Engineering, Airaid , American Products Co, Applied Racing Technologies, ATI, Auburn, Auto Rod Controls , Autometer, Baldwin Filters, BBB Industries, BCA, Blitz, Breeze, Cardone Industries, Carter, Centric Parts, Champ Filters, Champion, Clean Rite Products, Clevite, Coleman Cable, C-Tek, Daikin Clutches, Dayco, DEA, Dorman, Dutch Precision, Eastern Water Pumps, Eiko, Exide, Federal Mogul, First Choice, Fram, General Electric, GSP, Hastings, Haynes, Herrero & Sons, ITM Engine Components, JTT Products, Kimberly Clark, King Bearings, KYB, Lapointe, Lightning, Lisle Tool, Littlefuse, Luk, Lumiko USA Inc, Melling, MicronAir, Milton, Monroe, Moog, Motorad, National Engine Kits, National Oil Seals, Needa Parts Mfg., NGK, NorthEastern Plastics, Omega, Optima, Original Equipment, Peterson Lighting, Power Train Components, Precision, Pylon, Python, Retech, Rich Porter, ROCK, Rol Manufacturing, Safety Seal, SanTech, Siemens, Automotive Racing Products, B&B Manufacturing , B&B Performance, B&M Automotive , Baer Brakes , Barry Grant, BBK, Be-Cool Radiators , Bilstein , Blower Shop Inc, BMR Fabrication, Bully Dog, C.A.T. Power,MSD Ignition, National Engine Kit, NGK, Nitrous Oxide Systems, Northern Radiator, Offenhauser, Optima, PaceSetter, Painless Wiring, Patriot Performance, Percy's, Performance Analysis, Performance Automatic, Pertronix, Power Slot/Centric, PowerMaster, Pro/Race Balancers, Professional Products Performance, ProForm, PRW, QA1 Motorsports, Quick Fuel Technology, Canton Racing Proucts, Centerforce Clutches, Centerline Wheels, Chassis Engineering, Clevite, Cloyes, Cometic Gaskets, Comp Cams , Competition Engineering , Covercraft, Crane Cams, CSR Industries, Cyberdyne Inc, Dart Engineering , Dedenbear, Derale, Design Engineering Inc, DiabloSport, Diamond Racing Pistons, Dynamax/Thrush/Walker, Eagle Cranks, Earl's, Edelbrock, Edge Products, Eibach, Enderle Fuel Injection, Energy Suspension, Exedy Clutches, Fast Fluid Transfer, Fel-Pro, Ferrea Valves, Fidanza, FKB Bearings Inc, Flaming River, Flex-A-Lite, Flip-A-Dial, Flowmaster, Flowtech, Fluidamper, Fluidyne, Ford Racing Performance Parts, Fram, G-Force, Global West, Granatelli, Grant , H3R Fire Extinguishers, Hamburger, Harwood, Hastings, Hays Clutches , Hedman Hedders , Heidt's , Hitachi, Holley, Hooker , Hotchkiss, Hurst, Hypertech, Innovate Motorsports, Inventive Marketing, Isky Cams, Jackson Racing, JAZ Products, Jesel, Jet Performance, Joe's Racing Products, Johnson Seats, Jomar Engineering, JW Transmissions, Keith Black Pistons, Mallory Ignition, Manley, Maradyne, Marshall Engines, Marshall Gauges, McGard, McLeod Clutches, Melling, Mickey Thompson Tires, Mickey Thompson Wheels, Milodon, Mopar Performance, Moroso Performance, Moser , Motive Gear , MPR Inc, Mr. Gasket, Racing Power Company, Ram Clutches, Ratech, RCI, RHS - Comp Cams, Richmond Gear, RJS Safety Equipment, Roush Performance, Royal Purple, Rush Filters, Russell Performance, Design -- Cartech, Gear/DynaGear, Safecraft Equipment, Scat, SCE Gaskets, Scorpion Rockers, Skunk 2 Racing, Spectre Industries, Speed Pro, SRP/JE Pistons, Stage 8, Stainless Steel Brakes, Standard Abrasives, Stant Racing, Steeda Motorsports, Stop-Tech, Strange/US Gear, Stroud Safety Equipment, Sullivan Brothers, Super Chips, System One, T & D Machine, TA Performance Products, Taylor Cable, TCI, Thermotec, Tilton, Tokico Shocks, Total Seal, Trans-Dapt, Transmission Specialities, Turbo Action, Turbonetics, Ventshade Company, Vertex, VHT Paints , Vibrant Products, Vortech, Weiand , Weld Racing Wheels, Wilson Manifolds, Wilwood, Wolf Car Covers, Wolo, World Castings, World Wide Fuels,.. Mickey Thompson Tires, Mickey Thompson Wheels, Moser, Motive Gear, Performance Accessories, PIAA, Pilot, Putco,, Rancho, Ratech, Ready Lift, Richmond Gear, Skyjacker Suspension, Suncoast Hoods, Super Chips, Superlift, Suspension Techniques, Trux-Stuff, Valley Industries, Ventshade Company, Warn Winch, Westin, Airaid, Airlift, Auburn, Bell Tech, Bestop, Blower Drive Service, Bull Dog Winches, Bully Dog, Bushwacker, Carriage Works, DeeZee, DiabloSport, Edge Products, Energy Suspension, Extang, Fab-Tech, Firestone Industrial Products, Ground Force, Hellwig, Husky Liners, Hypertech, K & N, K.C. Hi-Lites, Lund Industries, Silvolite Pistons, Standard Crankshaft, Stewart Warner, Thermoid, Tridon Flashers, TYC, United Remanufacturing, Victor Products, Visteon, Wilmar Tools, ACI, ACL, Airtex, Ammex, AMS, Anco, Austin Baker, Autolite, Automatic Transmission Parts, Automotive Gold, B&B Manufacturing, hundreds more.
