NOT MINE!!!... OK guys decode this!!!
Mopar muscle car 1965 Plymouth fury convertible big block numbers matc - $4750 (Knox tn)
Ahh let's include the silly text too!
Jesus loves you ! Too many projects for me to fix. So here's your chance to own a matching numbers big block mopar muscle project car for under 5 k ! This will need a total restoration, it has clean tn title ,fender tag in photo, 383 super commando steel crank, hi- performance exhaust manifolds four barrel carb and intake. Has four speed clutch and brake pedals in car, someone was going to straight drive the car, not me.All pulleys , brackets, etc,power steering , manual brakes, power convertible top, top frame fair top motor runs but cylinders need replaced, this car needs full floor pans trunk pans, and lots of work, engine not running, 727 auto transmission in trunk has 8 3/4 rear end 741 case appears to be posi set but have not ever been pulled probably 3.55 gear set, unverified. Looks to have most of original paint it sat in the barn for a long time, all convertible trim stainless looks great, firewall looks good , rails appear ok . Car sold as is where is, must be towed. If you have 55 k and want a all matching 68 Plymouth convertible with all matching numbers and all original pans , that is ready to go I've got that too. If not ,then here is an affordable project car, that you can build at your leisure or do you need some nice parts for your convertible ? .Thanks for looking! Have a blessed day ! Please no texts or emails calls only. 865-742-71three nine I will call you back, and answer your questions, tell your friends about this car, this fury will make a beautiful car, rat rod, project or parts car!
post id: 6578767127 posted: 2018-05-03 12:46pm updated: 2018-05-04 9:41am
