65 Polara 500
To your question, why/how did it happen. I have no idea, I finally got everything separated, and when I did the flex plate dropped out of the bell housing along with 6 bolts, one was sheered off. This completely boggles my mind, I have no idea how the car drove home. So another topic, whit all of the work that I have put into this, I don’t want to have to do it again, I’m considering replacing the transmission or a rebuild. I know this tranny is unique because it has two shifting cables going to it. Is there a way of replacing the tranny and going to a one cableI see a couple folks are alluding to the elephant in the room here without just saying it..... What you are describing is a very rare situation.... HOW DID THIS HAPPEN??? Was it put together without torque applied to the bolts?? Is there an underlying issue; vibration, crank register, bolt holes or problem with the bolts themselves?? Flexplate damaged or warped?? You really need someone experienced to solve this before simply tightening the bolts and hoping for the best. Finding loose flex to converter bolts is a way more common issue. Best of luck.
Almost forgot... possibly you need offset dowels on the bellhousing because of an off-center crank to trans centerline issue??
To your question of why or how did they come loose. I have no idea, my guess is they were never installed properly. When I was able to back the transmission away from the engine to my surprise, the flex plate and all 6 bolts fell right out one both was sheered. It completely boggles my mind how I was able to drive home.I see a couple folks are alluding to the elephant in the room here without just saying it..... What you are describing is a very rare situation.... HOW DID THIS HAPPEN??? Was it put together without torque applied to the bolts?? Is there an underlying issue; vibration, crank register, bolt holes or problem with the bolts themselves?? Flexplate damaged or warped?? You really need someone experienced to solve this before simply tightening the bolts and hoping for the best. Finding loose flex to converter bolts is a way more common issue. Best of luck.
