Ok Dave voltage at coil ignition on is 8.21 volts, and on starting found the problem, first video the ground fell off before it cranked, notice no 12 volts, 2nd video it will show 16volt but too late.
This is going to be a wiring fault, trick will be to find it. I would run a continuity test on the ignition switch first. Also check the ground for the coil, if the coil is not bolted down firmly, it will not funcdtion, that is why they usually have two bolts to the intake manifold. Can't tell where you coil is mounted, if it is mounted to the fender well, that will need a ground strap from the block to the coil mount.
