Rathmore, we all would be able to help you out more if you didn't use your phone to do this.
Posted via Topify on Android
Air, fuel, squeeze, bang(spark).... Your missing one.
and to do that easiest way is to Pull out the dist and spin it 180 n drop it back in?
Yea, you could do that. Probably the easiest way to try it.
Or... pull #1 plug and put your thumb on the hole. When the compression comes up, bring the timing mark to zero. Point the rotor at #1 plug wire and bolt the distributor in.
Ok so Ill pull Number 1 in the morning and slide a straw down n in it to see when its at the top n make sure the rotors pointing
to it Thanks again everyone ill let yas know how it goes
