LocuMob
Fluid Technician with a hat
Any reason I'm having a hard time getting my torsion bar back in after taking it out to install my headers? The FSM doesn't say anything about it being clocked a certain way, but it is off a few degrees in back when input the front hex in the socket. Only goes in a tiny bit. I didn't remove it completely, so I know the ends are correct. Is there a simple way to turn the adjuster in the control arm? I've been prying it down to try to get the back hex lined up with its socket, but when I hit the tool on the bar the pry bar pops off. When I did this before the whole front end was tore apart so it was easy to move things around to get the bar in. It's pissing me off. Shouldn't be this hard. Hate to tear it all apart, but I could have done that and been done with less time involved. At least the header is in and looks good. I'll worknonbthe other side while you experts chime in. Do the happy dance, do the happy dance, do the happy dance.
