John FatFab
Perfect!
Thanks!
Thanks!
I saw this thread and thought I would post a close up of the hitch that came on mine. It does not look factory like the other posts on here but I thought it would give you an idea???For my 74 town and country wagon i love to pull a trailer behind it. So i need a trailer hitch.
Doos my wagon share that part with other c bodys . Or anyone has a lead to one.
Thank guys
Hey guys. Wel i did a bit of mcgyuvering here with a tutch of the a team aswel and this is what i came up with. I bolted al this to where the bumpersprins are atached. What do you guys think, is that gona hold up. ? Its onle for a 1000kg max trailer with windsurf gear.For my 74 town and country wagon i love to pull a trailer behind it. So i need a trailer hitch.
Thank guys
Sharp eaye mate. But if you look good you can see that the hole in the ballpeace stil needs to slide in bout 20 cm so that its way shorter .You say your trailer is 1000kg. That means you need 100kg on the tongue. Looks like your ball is 30cm from the bumper mounts. That puts significant torque on that member. You should consider transferring that torque forward along the main frame rails.
Always remember that "strong enough" may not be not be adequate if more load is added or an unforseen circumstance adds to the stress. Think also of possible liability consequences of a failure.
Just a few thoughts from an old guy who has built several hitches. Lindsay
Some beter pics on where i did bolt it on.Sharp eaye mate. But if you look good you can see that the hole in the ballpeace stil needs to slide in bout 20 cm so that its way shorter .
Also trailers here have les tongeu weagth . Prob 50 to 70 kg . Dont know why thats diferent here lol.
