Hi guys - working through some stuff on a recently acquired 1966 Chrysler Newport.
Question: If the turn signal bulb behind the instrument panel is out, will that impede the flashing of the external turn signals?
When I turn on the separate flasher switch, they blink at all 4 corners. Drivers side blinkers work from the stalk, as does the light behind the instrument panel. The passenger side blinkers from the stalk has them light up, but they do not flash, and the bulb behind the instrument panel IS out.
New flasher relay installed so I don't think that's the cause.
Thanks!
Thanks!
