Turn Signal Switch?
Ram Fury
Colorado Springs, CO
My '65 Sport Fury's passenger side brake lights don't go on even though the tail lights and right rear turn signal work perfectly. Going through the electrical system, it seems as though the turn signal switch itself is on the fritz. Can anyone refer me to source for such a critter?
I would appreciate any help I can get.
Joe Godec
If you don’t have a tilt column, Rock Auto has the turn signal switch. The non-tilt switch is easy to obtain.
if it is tilt, a mid '60s chevy El Camino with tilt uses the same switch (down at the firewall), It is much less expensive than a MoPar PN. I have one on my '66 Monaco.
I believe I purchased it from Summit racing for about $80
I see on Rock Auto there are two turn signal switches. If you have cornering lights will part number SM107 will work? It does not say in the description like it does for SM106 that states (w/o Tilt Wheel; w/o T&T Wheel; w/o Cornering Lights; Chrysler Built Column)
jumping on this thread. I have a 67 with tilt-scope. I'm rebuilding the steering box so this is the perfect time to refresh the column......but the little bit i'm digging in, the actual switch itself is near unobtainium, and I'm not clear on the GM part that should work.
To add, this column seems like it's gonna bit a total pain in the rear to pull apart........
The switch I bought is GM P/N 73-01993624, it fits my 1966 Monaco tilt, other years, I don't know
Lads --
Thanks for the lead on Rock Auto. I was able to get the switch (for about 98 bucks) from them. A friend of mine and I put in about four hours of hard work punctuated with beaucoup profanities, but we got it in yesterday and it seems to work fine.
Thanx again,
Joe
