Typical window regulator issue?
Rustyrodknocker
Salem oregon
I recently purchased a 70 Polara with a known manual window regulator issue. The previous owners had it up to about 4" from all the way up and taped the rest to keep critters out. I had figured i could get it to stay up by some means quickly as it was delivered to my storage and it's not a place to be wrenching on cars..
Any how I accidentally leaned on the glass and it dropped all the way down.. I tried rolling it up and pulling it up and I couldn't get it for the longest time it seemed, in the blistering heat. No engagement at the crank . Finally it came loose and I pulled it all the way up and wedged a small stick to maintain pressure to prevent it from falling..
However I don't like worrying about it coming down and a raccoon or cat moving in. It does have a nice fabric seat..
So the question is, Is there a typical scenario that is common with these regulators?
I have never had this issue with my other fuselage cars..
Im hoping to be able to take the parts I need and get door panels off and fix the regulator in a short time span as to not look like im doing what im doing...
It sounds like the plastic piece that holds the track to the window glass may have disintegrated. The track sits on the bottom of the glass. The glass has a hole that lines up with the holes on the track. There is a gasket that wraps around the glass, that is probably toast as well.
This is the plastic retainer and gasket I needed to for my 68, I would think it hadn’t changed by 1970
