Agreed - sorry if I wasn't clear - the assumption I made is that this step is in addition to correcting issue that exists at the bulkhead, which is that the hot feed to the ammeter (red wire), which connects to the black wire side of the gauge comes through the firewall in a way that bypasses the bulkhead, as recommended in this whole thread. As well, it was assumed that the black wire that goes to the main power distribution splice (factory wire weld) under the dash, and subsequently goes back out to the alternator (with the attendent fusible link to protect things), passes through the firewall safely, bypassing the bulkhead as recommended.
What I did was run new 10 AWG wires, unbroken, to and from through the speedo cable grommet, and added a terminal block on the inner fender, to which I added a mini-circuit with a new fusible link on bith the red AND black wires, to add and enhance the level of protection as was there originally.
