300rag
Yes, same here on the passenger side. The hanger will bolt into the original holes on the driver side OK, but the "tabs" for the insulator are flat against the bottom of the trunk floor. There is no way the insulators will go on.
I'll probably just redesign the bracket to fit.
The tail pipes slide in from the rear just fine. The instructions say start from the rear but I think that is misleading. From the manifolds back worked best for me.
The reason for starting at the back is that it is much easier to get the tailpipes on the hangers. Once they are secured on all 4 hangers the mufflers hang on nicely and are held in place, then the H slides on, and then the front section just pops in, then tweak and clamp. YMMV.
