I'm in the process of replacing the rear drums on my '69 Chrysler 300. The only thing I'm stuck on is the horseshoe clip and wave washer for the parking brake lever. It SEEMS pretty straight forward, washer and then the clip, but is there any special procedure or tool I would need to make sure it all stays put? (see attached pictures of hardware kit and what was on the car (right rear).
Also, the wave washer looks to still be in decent shape (I had to pry them off with a screw driver and pliers). But if I need to replace it, where would I find them. They're 1 cm inner diameter, 2 cm outer.
