70NewY’ER
Hello everyone. I haven’t been updating in a while from being too busy. I’ve been working/ having work done on the Newport since my last post. I swapped out a lot of parts (both axle shafts, wheel cylinders, and even the rear passenger backing plate), and had the brakes adjusted a few times. The problem still lingers on. I just recently disconnected the parking brake cables to see if they were hanging up. Still hot. Temp maxed out at ~500 degrees F on the pass. rear, and ~300 on the driver rear. Fronts averaged 160. I’m going to start fresh on the rear adjustment and I will use the original drums (both were recently cut). With Carlisle coming up, I’m going to work as hard as I can to get this squared away. Any feedback would be appreciated. Thanks!!
