Knebel
I apologize for opening a new topic about this, but there is still some weird stuff happening with my charging system. I just cant figure this out.
Brand new 90amp alternator
Electronic voltage regulator
Direct 8ga with 100amp circuit breaker to battery from charging stud
Ammeter NOT bypassed yet
So... when I drive the car in the day, i see a good 13.8volts on my voltgauge. My ammeter is about straight in the middle because most of the current goes through the 8ga directly to the battery. when my fan kicks on, I see 13.2 to 13.5volt. That dosent really change and seems very stable.
Now tonight, I drove the car in the dark with the lights on and when the fan kicks on, i saw about 13volts. It seemed fine but then all the sudden i see the ammeter jumping up to the positive side (not all the way) and the lights get a little brighter (assuming the fan kicked on and the alternator needs to put out more current). That happened off and on a bit with the ammeter going back to middle and then back up, like... cycling on/off something, like...the fan. now the kicker, i see only 12 to barely 12.5volt not increasing when the rpms go up while i drive. Im like "wtf is happening???".
all the sudden, the voltage goes back up to just the normal 13v i saw before with the fan and lights on. I watch the ammeter and its still doing the thing like switching some load on and off now and then but the voltage stays at 13v but later on goes back down.
conclusion, the voltage changing is not parallel with the jump in the ammeter. Whats going on there? Is the alternator just putting out more current to keep up? but why does the voltage drop so low? 12v is waaaay too low in my eyes even when drawing 50amps at idle. My alternator sheet says 57amps or so output at idle.
Edit: the jump in the ammeter seems very hard, like a switch, i verified and it still happens when the electric fan is already on, so it can be that. Can someone explain how the alternator gets excited with the external voltage regulator?
