73Coupe
I had some time away from the client above while I waited for other trades to finish their work so I took this job.
Before…View attachment 506869View attachment 506870
Looks like some creative artwork right there.....
"What are you working on today?".....
Helping and documenting my stepdad with getting YET ANOTHER c-body today that we got from our good friend and a member here, AND that I really wish was mine. It is a '67 LL1 Dark Turquoise VIP fast-top with a black interior, black vinyl top, a "G" code 383 2bbl and air.
We need some pic's
Ah yes, her yard signs…
This is good timing as I have one except it’s blue and is just now starting to act up after no less than 25 years of service as one of my favorite hand tools.Decided to overhaul my favorite screwdriver.
In 1988 I bought my first Snap-On tool. It was a ratcheting screw driver/nut driver SSDMR4A. It had a removable cap to store the different bits and 1/4” driver. It seems to me that it was just under $30 and probably the cheapest tool he had in the truck. I used the hell out of it and likely got my money’s worth many times over. I still have all the original bits except for the 2 Phillips which I lost. I had to be careful with it as it had such a nice handle it was easy to strip screws or small bolts. It also had the finest ratcheting mechanism of any driver I have ever tried. Many ratcheting drivers will turn the screw backwards on the ratchet stroke but with not this one.
After 32 years it was starting to slip and get difficult to change directions. I was always going to chase down a Snap-on truck, but never got around to it. So I decided to take it apart and see if I could fix it. It was fairly dirty and gummy inside, so cleaned it with brake cleaner and re-oiled the gears, detent and shaft. Put it back together and now works like new.
View attachment 511410View attachment 511411View attachment 511412
Make sure you have a tray and your readers on. The little balls and springs are tiny. Also the retaining ring is much easier to remove than to re-install. It took me a few tries.This is good timing as I have one except it’s blue and is just now starting to act up after no less than 25 years of service as one of my favorite hand tools.
Emergency brake lever on both sides was frozen.Finally getting the emergency brakes on my 2002 F-350 straightened out.
Brackets from the cable to the brake shoes are frozen and the shoes are shot.
View attachment 511514View attachment 511515
Yuck, been there plenty of times before. Glad it's coming back together though!Emergency brake lever on both sides was frozen.
Cleaned up the passenger side and will reassemble next week as family duties are a higher priority.
Bummer that you discovered the failure. Yes, the brakes will come back together.Yuck, been there plenty of times before. Glad it's coming back together though!
This was what I encountered a few weeks back on my '99 7.3. Had a cylinder drop out on the way to work, and had to drive it home shuddering the whole way. Buzz tested it at our shop at work, all buzzed good. Not enough blow by to signify a toasted cylinder, and I didn't have any of the symptoms of a blown head gasket, so I was thinking injector hold down (even though I'm VERY particular when I do an injector job). Checked all my injector hold downs, tight. Checked all my glow plugs, tight, but when I got to the #1 cylinder to pull the glow plug pigtail, I heard a "clink." Looked down and saw that both pushrods were disengaged from the rocker. Then I went to grab them to pull them out, and the broken one fell down into the engine. A few minutes of fishing with a magnet, and I had everything out. Checked the others for play, and all seemed well. Fairly certain the rods were bent when I bought it, and then I "did it in" when I put my new injectors in it. Could be that I just floated a valve too (with my wastegate unplugged she'll hit and hold 35 psi), but given some of the other stuff that I saw, and the fact that the old boy before me rebuilt a 7.3 at 200,000 miles, kind of indicates that something went boom prior to me owning it.
