MoPar Maniac
The blocks are not the same dimensionally. If they shaved weight it was on the outside so the block is smaller. The bore/stroke and bore spacing are the same.The blocks are dementially the same. The LA blocks are a thinner casting and used way lighter/compact heads, hence the term light A (LA), this was to fit into smaller engine compartments (A body). The reason the lifter bores are so low on the cam is leftover from the poly, bolt a set of poly heads on a LA block and see how well the push rods line up. Pistons and cam are different as mentioned
Poly crank wont work in late 273-360. Thats from the guys who designed them.
