Some of the 1973 Fury Pursuit special equipment and markings my Fury III has include a labeled switch to turn the AC off when over 85 mph to totally disable the compressor, a knob labled lock to fast idle, (this must be to boost rpm for the alternator to run all lights when parked, unit number painted in lower door jam, certified 140 speedo, traction Lok rear end, sway bars, battery shield, one key fits every lock on car even glove box, head liner has switch with reading light between visors, 440 steel crank shaft E86, U code engine, extra wide rims painted body color of brown, note 1973 is the first year for colored NE hwy patrol cars, whip antenna with antenna lock forward on windshield. Many F codes, roof reinforced, body extra weld options, special order stamp and added fender tag tab.
Can you post pictures of your fender tags?
