516 (361-383 c.i.) is the other #. (it's a poop head) There are two 915 heads, one with 1.60'' and the other with 1.74'' exhaust valves. Although I have never seen a 915 head ''stamped HP'' I agree 100% with Matt. either way both heads are great, and the larger valves can be installed where the smaller ones reside.
The compression increase you should expect is closer to .8 than 1.0, provided you remove the difference in thickness of the aftermarket head gasket v/s the factory steel shim style, from the head itself.
