I know this thread started a while ago, but it is still an ongoing topic to consider. The standards for motor oil have continued to change more and more formulations to less and less antiwear agents (ZDDP...) to meet with federal emission standards. Face it, in the grand scheme of things there just isn't enough market for these products and it will continue to diminish. I have been looking at and carefully considering this stuff too.
FWIW, I am a long time user of Wix filters (or NAPA gold) and have had a small number of failures over the decades. Usually on older sludgey engines where the complaint related to low pressure at stoplights, new filter always solved that issue in my experience and there is a pressure relief valve built in if the filter was immediately restricted by fresh oil cleaning up the evils. Always just warrantied them, never cut on open, and the problem never returned. I have avoided Fram since the late 80s early 90s when the cutaway displays started to show up. I suppose I will continue to use them until they prove to be lesser quality.
I hate this, but I have had a fair number of incorrectly cut threads on Wix and some other brands over the years, but at 500+ filters a year... you will find defects.
As to motor oil, I am still undecided. I heard some Rotella is still made for older engines but CJ-4 rating is lower zinc formula. Also diesel oils may not provide as much storage protection. Amsoil ZROD sounds interesting, but I am not sure I love synthetic for this application. Brad Penn is the old Kendall refinery's new label after the name was sold away, I can not swear they are still using "obsolete" oil formulations. There are several performance and classic oriented brands, but I am not a believer. I have read the claim that Mobil 1 15W50 is an older formula, but doubt it has stayed that way...
What I really want to know is... does anybody have a compelling reason for use of a brand that is based on current information? Past experience really doesn't count as more oils are rated SL, SM, SN all the time and they DO NOT contain the antiwear additives we may be looking for.
How many of you have experienced oil leaks with the change to synthetics? That is supposed to be the common issue with their use in older engine designs (rope seals). Also low viscosity can lead to lower oil pressure on older engines which have much larger clearances than newer engines. I doubt we could trace many failures directly to a newer grade of oil in a high mile engine, but it is a scary thought that your favorite classic could be sidelined by this issue.
At some point the emission liability and low demand will pretty much eliminate the availability of "flat tappet" oils and we will all be on borrowed time. Like leaded fuels, I believe there will still be lots of engines that survive, even if there are also documented failures. The best thing is to change it often enough and run it often enough... IDK if anything else is really a cure or just the placebo effect.
