MEV, please share your set up.
440 .030 over (bored in the garage with a 40 year old bolt-on portable boring machine, no torque plates or anything)
440 source 505/512 stroker kit
stealth heads (bought the regular stealths and went 12.60's, later had them CNC'd at modern cylinderhead)
440 source 1.5 roller rockers and shafts (fit under stock valve covers, but added 440 source fabbed aluminum valve covers to stop leaks)
Chris straub custom hydraulic roller cam @.050 234 244 Lift .573 .563 (I initially used the comp XR280HR, hydraulic roller a tons of bottom end and mid-range and a strong top-end (but all done by 5600 RPM) I did have a premature hydraulic lifter failure and comp flipped me the bird so i went with straub technologies, and used their morel brand lifters. It is WAY better than the comp stick and lifters. It has more bottom end, more midrange, and it is absolutely fierce on the top-end, and the vacuum brakes work great)
TTI c-body full exhaust with cross-over pipe (originally had log style exhaust manifolds went 12.80's)
Performer RPM manifold
Quick Fuel SS830 carb (electric choke, mechanical secondaries) 1/4" phenolic spacer
melling high pressure, stock volume oil pump
Holley mechanical fuel pump stock 5/16" fuel line
No-name 2800 stall converter
Detroit locker with 3.23 gears, stock axles, green bearing conversion, m&h 275/60/15 drag radials
