WANTED Windshield Washer Pump - 1970 Custom Suburban
MacsGarage
Scottsdale AZ
Hey there, hope everyone had a great Thanksgiving weekend!
I am online once more, looking for yet another oddball piece to the great big puzzle that is my 1970 Custom Suburban. I am in search of the windshield washer pump as I am close to finishing the washer system for the car. I thankfully managed to source a reservoir, replaced the chewed area of the harness which connects to the pump, found and installed the correct plastic tee up into the hood which branches the lines to each respective squirter. All I need is the pump. I understand that there are aftermarket units for sale, however I'm after a correct style pump as mine has both a broken ground wire as well as snapped threads that will no loner sit far enough up into the tank to accept the plastic screw on screen filter w/ gasket. It's a bit OCD, sure... but I'd like to find a matching style with the white plastic body, downwards facing nozzle for the washer line and a correct style ground wire connector (almost a sleeve-like ring terminal which clicked into one of the plastic screw mounting tab holes of the reservoir to the body. Any help or point in the right direction would be much appreciated. (photos of the pump w/ broken connector below)
Thank you for your time,
Mac
Holy moly man... how in the world have you got so many? That collection is incredible! Would you happen to have one which fits the nozzle placement, and has the correct style ground wire with "sleeve-like" ring terminal? Edit: I just read fully through your post... my apologies for not doing that the first time. I don't know what the name is for that style of ring terminal, but if it would be possible to adapt to the ground wire, that would be fantastic. The one in the photos I took is a Delman. The car was assembled in May of 1970. What do you have that fits the bill as far as date coded goes?
Please get back to me when you can, thank you
If it happens that Bruce does not have one I think I do.
