commando1
How did you trace it. Pulling a vacuum pump?
Yup, got some extra hose, detached one end at each point, plugged one side, pushed on the extra hose on the other and sucked and blew into it. I got sore cheeks after doing that for awhile. I could actually hear the leak when I put my head under the dash. What put me off early was the fact I had multiple leaks...How did you trace it. Pulling a vacuum pump?
A tad too cool, don'tcha think.
Modern oils need to run in the -+190 zone.
Yes I have been manually actuating the ones I can reach and have found the one at the top right hand corner is a bit sticky. The pivot points on the rods though are all well greased with a yellow substance, I think its the original stuff but is still good.I would add that you manually move the doors that the actuators control in the hvac and even lube them at there pivot points to make sure they operate as they should and aren't obstructed.
It is touch and go at the moment, I still have a few things to sort on the car and right now its 95 degrees with a heat index of 116, plus the day is getting hotter. I don't want to say it but going to Carlisle is looking iffy. Sighs. Would have been my very first show.Are you still heading out for Carlisle at some point?
Yah that was the first thing i looked at when I puled up on the side of the road, everything is factory original and in its correct place though, so there was nothing to see. I was thinking heat may have done it, but then again, the car has been running fine on multiple trips up to now. I haven't changed anything mechanically, other than some fine tuning.make sure gas lines are clear of heat sources.. or gas will heat up and perculate giving you similar symptoms to fuel filter type issues ect or what your describing now...easy check and fix
I ran into this trying to get my convertible on the road for what ended up being "the comfort tour". The car kept throwing curve balls no matter how diligent I was being. It was almost like it knew a 2K mile road trip a week after a complete drive train rebuild was not a good idea.I have also decided now that I wont make it to Carlisle, I cannot know if it will run reliably on a 400 mile run there even if I do sort it out tomorrow.
BLah.
They have a mind of their own sometimes don't they?I ran into this trying to get my convertible on the road for what ended up being "the comfort tour". The car kept throwing curve balls no matter how diligent I was being. It was almost like it knew a 2K mile road trip a week after a complete drive train rebuild was not a good idea.
Yah , I'm going to check the most obvious causes and take my time now, try and not miss the simple things, it almost always ends up being something small.A similar thing was happening to my 300 coupe. It was a combination of a small blockage in the fuel line, perforated hose and loose hose connector at the fuel pump. I didn't see the first three times, just a thought since you've been through the fuel line already. On the positive, all the heavy lifting is done, you have time now to figure out all this little crap without the added pressure of trying to get to the show, and possibly getting stuck somewhere between NC and PA.
