volksworld
couple things...(just found this thread)...I installed the same quartz clock kit as you over 20 yrs ago and it still works fine...I agree with Cbarge about stainless lines, had a rear brake line on my pickup that gave me fits... never again...the transmission lines I got from Inline Tube for my 68 weren't even close... I have a big block so maybe you'll get lucky...wound up getting them from Vans instead and the first set from them was wrong too but after going over pics with their tech guy we found a 67 set that worked and they sent them out no charge and let me keep the others....there is supposed to be a hole in the fender well under the battery that lines up with the drain hole in the battery tray...so what you have there may be rusted a bit larger but don't be like the PO of my car that welded it up completely...fortunately he did a bad enough job that i was able to get the patch off...I'm also curious what the white paneling on your garage walls and ceiling is made of...is that steel? looks great
