Mopar_Mudder
From what I read no one offers a truck floor other the C2C and that one isn't worth getting. Just want to make sure nothing else is available before I make my own.
I would just add that I was actually surprised at how thin the trunk floor metal was in those early 60s Chrysler trunk floors and it is no wonder they didn't do well in the real world rust wise. It was significantly more thin than in our C bodies at least. So the C2C ones likely aren't far off in terms of thickness than the original ones.It would seem that somebody with decent fab skills and a HUGE bead rolling contraption could easily make a trunk floor piece. Using the correct thickness and quality of flat sheet metal, too. Having the capabilities to make something that size can be expensive, I suspect, but doable. In any event, some "cut and fit", weld and seal, metal prep and paint, would be needed.
Beautiful work. Could you share your process for making it?Well just wanted to update that I did end up making my own floor pan.
Lots of practice and trial and error with a bead roller LOL.Beautiful work. Could you share your process for making it?
