Well guys I finally had a chance to get in and take a look now that I knew what to look for....and I was TOTALLY wrong. The over-center spring IS installed, but the Z bar is not installed properly. It looks like it is clocked forward of where is should be so the over-center spring only has about 1/2 the amount of travel it should. It's like they installed the Z bar with it turned forward about 45 degrees of where it should be, if that makes sense. I don't understand why other than they just thought that's how it should be. I also can't figure out why they went to the trouble of welding a tab to the z bar to add another spring to bring the clutch pedal back up. Seems like more work than just doing it the right way? I'm definitely going to have to bring it to a shop that knows how to do this right, it is beyond my level. There may be more to it other than the Z bar but it sure looks like that's the main source of the issues from what I can see. As I mentioned before I don't have any experience with 4 speeds so I am about as far from an expert as it gets with this.
