If it works, who cares?!View attachment 555460
Yup, towed my engine attached to the crane, with my lawn mower. Necessity is the mother of invention.
PH23: Plymouth, High Price Class, 2 dr hardtopI'm not aiming for longevity in this case, the engine is too far gone for that.
Just enough to get it going.
Also, hot on the heels of another thread, can anyone tell me a bit more than I already know about the way my car left the factory?
Thanks
Phil
Having the correct bolts really helps- with the taper thread that'll catch and pull themselves into line. Mine are just regular grade 8 bolts and washers.How did you get the trans mount to line up so you could install the bolts? My car has had the same issue for a long time.
Thanks, Another afternoon project.Having the correct bolts really helps- with the taper thread that'll catch and pull themselves into line. Mine are just regular grade 8 bolts and washers.
Support the gearbox up away from the mount.
Grease or oil the mating faces of the beam and recievers. The beam must slide easily.
1. I loosely fitted the center two on the left, that gave a pivot point.
2. Push up on the other side with a jack.
3. Insert other inner bolts.
That leaves it sitting with the lower bolt holes splayed out.
4. Jack up on the outer edge.
5. Fit bolts, then the other side the same method (6, 7).
After that fit the two vertical ones up inside tightly, and then tighten down the rest. Do not use the vertically mounted ones to pull it into line. All it does it stretch the metal out of shape. Push it upwards with a jack. Just take care to not lift the car up off the stands!
Took about 30 minutes, working under the car.
Phil
They look great on there too!Via our very own @65fury I now have a pair of highly servicable sail panel trims for my car.
They match the brightwork on the car, which is perfect.
Phil
