PART 2/2
The original Shim underneath the inner Pinion Bearing Race was damaged from hammering out the old Race. Unfortunately, in the Doctor Diff rebuild Kit, there were no shims to replace it. But there were Shims to go underneath the Pinion Bearing itself.
In my Mind, it doesn’t matter if the Shims are underneath the Race or the Bearing itself. The position of the Pinion Gear inside the Housing should be the same. Is that correct?
Since my Bearing Race installing tool was not big enough, I had a fitting disc laser cut to press in the Race.
Using the Setup Bearings, the Pinion Gear went into the Housing.
What’s the correct order to reassemble and adjust everything correctly now?
Is my List correct?
1. Setting up a baseline with Shims to set the Pinion Depth
(measuring the stock shims and use the same thickness as a start)
2. Checking and setting up Carrier Bearing Preload.
Setting it by turning both the adjusters with a Spanner Wrench towards each other.
But how do I check it?
3. Checking and setting up Ring/Pinion Bachlash by turning both the adjusters the same amount on each side until the Backlash is.. what?
The Book gives me three different ranges on different Chapters of the book.
.005 – .0015
.008 – .012
.06 – .08
4. If everything is set, I have to check the tooth contact pattern with the yellow grease.
If it’s wrong, it’s another story of its own... But first things first…
I hope someone can answer all the Questions (marked in red) I have so far.
Thanks!
Is my List correct?
.005 – .0015
.008 – .012
.06 – .08
Thanks!
