7071 chally
Hi guys... I'm working on a friend's 1969 Plymouth Subarban and the power window is not working in his tailgate. He replaced the motor (that came from a 72 Monaco wagon). If I apply power to the motor, window moves up and down. I had no power at the power assist relay, which is now fixed. I have 3 wires at the switch (Tan, Red, Yellow). When the power assist relay is energized, I have power on the Red wire at the switch. If I flip the switch up, I have power on the brown wire way down to the tailgate motor, but the motor is not moving. If I flip the switch to the down position, I now have power on the yellow wire way down to the tailgate motor, but motor is not moving. The thing is, I'm getting no ground to the motor. When the brown wire has power, the yellow wire should be a ground and vice versa. If I disconnect the switch in the cluster and I apply power and ground to the yellow and brown wires (at the switch plug) motor turns fine, so the circuit is good. I checked the wiring diagram and I can't figure out how the motor should get ''down'' or ''up'' ground. I have power the ''Up'' and ''down'' position, but I never have a ground. How is the circuit suppose to send a ground to the motor? Am I missing something? TIA
