75LandYacht
Yank Tank
Bob, following Stan’s idea of a shaker hood, I’m sure there are plenty of used formal hoods around, maybe you could find one and sacrifice it as a template just to see how it looks and works.. just a thought.
Pfffttt... Pocket change.$2700 for a BB 4 bbl kit.
Wouldn't a small inline fuel pump to help keep fuel in the bowls a better alternative to the insulator?
Sounds like a lot of work, everything under the hood looks so awesome as it sits.
I do need to take a step back and try to think this thing out a bit.
It's a vapor lock problem. Engine starts fine and runs great cold and for about 30 minutes. After about 30 minutes the engine will just quit running like it's out of gas. If I coast to the side of the road and wait a couple of minutes it will start up and run a little bit and then the engine will quit again. If I park like when at a restaurant for about 30 minutes it will be pretty hard to start. The fuel line is routed up next to the aluminum water pump housing, aluminum cylinder head and not far away from the exhaust and intake manifolds. All generating a tremendous amount of heat.
IMHO, I don't think the carb insulator is going to cure your issue. In my experience, you'll do more to isolate and insulate the fuel line. Couple that with an electric fuel pump and your problem should be solved. I'd give some consideration to removing the stock pump too.It's a vapor lock problem. Engine starts fine and runs great cold and for about 30 minutes. After about 30 minutes the engine will just quit running like it's out of gas. If I coast to the side of the road and wait a couple of minutes it will start up and run a little bit and then the engine will quit again. If I park like when at a restaurant for about 30 minutes it will be pretty hard to start. The fuel line is routed up next to the aluminum water pump housing, aluminum cylinder head and not far away from the exhaust and intake manifolds. All generating a tremendous amount of heat.
I already have a plan to wrap the fuel line from the pump to the carb with this heat shield tape.
Summit Racing® Heat Tape SUM-350122
