70NPORT
Although I have yet to nail this, thIS issue does not reside with the starter motor....
In the last month maybe less I've installed no less than 4 starter units on the car AND the very same 4 tested stand alone (off the car). All (except one...which I knew was defective) operated normally via jumper cables and the battery. Full current was applied and they worked perfectly each time. The starter I have now is a little less than 2 weeks old. I tried it stand alone before bolting it up. It worked perfectly then. It is highly unlikely it is malfunctioning. Just ten minutes ago I went I and tried it. The motor started with barely a twist of the key...as if nothing ever happened. This same behavior occurred with each other starter I had installed. This says to me the issue resides elsewhere.
