Update.
Today I manage to get some time in the garage and testdriving.
The temperature went from 44"F (7"C) to 55"F (13"C) since I did my last testdrive.
I didn't change the main jet, still .110 but I turn the AVS another half turn.
I didn't change the nossels, still .040
I didn't cange the timing, still 18"
I DID change the rod to one step richer at the power to primaries. Pimary jet .098 and .063/.047 rod (.062/.052 rod before).
The result is much better, the hesitation is almost gone.
I did notice that when I let the secondaries open evere so slightly and then floor it there is no hesitation, it goes rich direct without a lean spot, but if I floor it from cruise and it result in a kickdown then the lean spot/hesitation is there but not at much as before (outside temperaure, AVS adjustment or the richer rod?).
I also notice that some WOT testing was about afr 12.5-13.5 but some of them was more at 14-14.5 at the same run just a minute after the other between I floor it from cruise at highway.
It pulls real good and I can't notice any detonation but afr over 14 at WOT is a bit lean to me.
Another thing I notice was that if I accelerate from low rpm at the power on the primaries (less than 6 inches of vacuum) the afr get leaner as the rpm rises,
