Incognito upgrades are neat to do, to me. I hid the MSD 5C box behind the lh headlight, attached to a fender extension stud that was electrically hot. Ran the wire in the loom to the voltage regulator area, then across the cowl and down the rh valve cover to the distributor, along with the extra wire to the elec choke on the carb. Look for it, and it's there. Otherwise, it's hidden and only somebody that knows what to look for will not see the extra wire from the distributor or in the loom as it goes over the lh frt fender trough.
Do the math and determine the basic pipe diameter of the exit of the y-pipe needed to equal or exceed the area of the dual 2.25" pipes TO the end of the y-pipe. Then go from there to find a muffler with such resultant pipe diameter. Then carefully snake it around the rh rr shock absorber and between the rear rail and gas tank. The bend over the rh rr shock and rear axle would also need to be a compound mandrel bend, if possible. Use the OEM '72 Imperial single exhaust system as a guide.
