live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,730
- Reaction score
- 8,924
Well, the first post on this thread was 7/22, nearly two months ago. This job has been nothing short of one frustration after the other. I posted in a separate thread that I couldn't get the heater hose nipples off.
Copper corrosion - heater tubes stuck
Once I had it apart and could verify that the box I had blasted and painted up was identical I got it insulated. The I installed the evaporator core that I previously had tested.
I applied all of the foam bits to the new heater core, installed the "h" valve and installed the heater core. This caused me to discover that the core was not made correctly. Coolant connection that the heater tubes goes over was 3/8" of an inch too long. It stuck out of the box instead of being recessed inside. Some calls and emails with the supplier and they shared that all of them in their stock measured the same as the one they had sent me. Really! It's getting sent back tomorrow.
I found another supplier (actual manufacturer) and after many texts and emails with pictures of measurements I decided to give their core a try. It came today. The coolant connection was positioned much better. It was recessed about an 1/8" too far, but because of the way the heater tubes connect I think it will be fine. The bad, the holes in the mounting plate are not correct and the one side of it was a little too short. A drill and a piece of sheet metal fixed these problems. This is the company that Steve @saforwardlook has mentioned in the past. I'm so glad I could make this work. On top of that it was bad in the US.
Now I just need to come up with some foam gasketing to put on it since I used it on the first one and it did not come off in a reusable condition. I'll have to poke around at work tomorrow to see what I can find. If nothing else a stop to Home Depot.
In the end if I could taken the mounting plate from the one and the cores from the other I would've had a perfect unit.
Just maybe tomorrow night I'll get the box halves back together and I can start to mount the linkage for running the doors. Oh, how I hope the pictures I took are good enough to get it right !
