thethee
A picture would help understand your post
Then why does the ECU get power from 2 sources at start up? Did Chrysler design redundancy intentionally? If not and power at start only comes from ignition run, the ECU side of the dual ballast resistor is pointless engineering.Maybe I wasn't clear, yes, I agree that the blue wire is ignition run. However, I'm certain ignition run is hot during start as power is back fed through the ballast resistor from ignition start circuit.
With the newer 4 pin ECU's the J4 from your diagram is the missing one so I doubt it's the power supply during start. So I think you should check power at J2E-18LBY* but I might be wrong and you're right and hopefully @Big_John will set us straight.
At start, effectively current makes a u-turn at the top of the ballast resistor, thanks to the jumper from one side to the other. If incoming voltage at the brown wire is 10.75 and outgoing at the green/red wire is 6.84, the ECU may not have enough voltage/current to operate during start.
OK, here's the measurements. the one you requested is bold.Maybe I wasn't clear, yes, I agree that the blue wire is ignition run. However, I'm certain ignition run is hot during start as power is back fed through the ballast resistor from ignition start circuit. With the newer 4 pin ECU's the J4 from your diagram is the missing one so I doubt it's the power supply during start. So I think you should check power at J2E-18LBY* but I might be wrong and you're right and hopefully @Big_John will set us straight.
· 10.65 V at Brown coil positive wire
· 10.56 V at Brown starting system wire at bottom left of the ballast resistor
· 8.08 V at jumper wire from top left of ballast resistor to top right
· 8.09 V at ignition run wire, blue, top right of ballast resistor
· 8.09 V at dark green/red power to the ECU wire at bottom right of ballast resistor
Description is right:Great info, I think we're getting closer!
Your description and picture don't match. Assuming bottom right, blue connector is your starting wire (as it should be) there is no way you should be getting 8.09 V at the bottom left, red connector as current would pass through both sides of the ballast resistor to get there. As you say that the left side (correct?) of the BR is reading at 5.2 ohms I'm starting to think you might have a short or wrong connection somewhere. Can you confirm the red/green wire is intact and only connected to ECU and bottom left of ballast resistor?
Thanks Ben, in that case I can only reach the same conclusions as you do and I hope swapping the ballast resistor and fixing the voltage drop do the trick for you. Wish I could've been more helpful.
Theo
Replacing the ballast resistor with a new Standard BR did not change the voltage readings. Beyond that, I haven't had time to work on the Monaco. Timing chain job on my DD pickup, plus an impending kitchen remodel have taken up most of my time.I would move the coil. The high voltage main wire is really close, possibly touching? The two low voltage components right beside it.
