70bigblockdodge
The 915 will increase compression ratio but to get a actual number you need to cc and measure how far down in hole the piston is plus gasket volume.
Yes the Stealth heads will increase the compression but the greatest power increase will come from the better airflow.
Things bother me though, 74cc? The earlier Stealth heads we 84 cc and when they constantly had the head gaskets hanging into the combustion chamber they were change to 80 cc. If they really are 74cc now they must have been milled. If they were milled you may find that your pushrods are too long now. If they started as the early 84cc heads and were milled to 74cc that would have been about .060" worth of milling. Then the intake surface of the heads would have needed to be milled .075" so the intake ports and bolt holes would still line up with the intake manifold.
Best to make some further inquiries before purchasing those heads.
Oh just been waiting for Spring to get here. The Newport doesn't get the heated under the house garage spot The Road Runner has claimed that spot it's down to bare metal. So too cold to work on the port but I did just get a new wielder so she'll be getting her hump as soon as it warms up. Trying to make some more HP out of the engine that's in it also My buddy's the one who is selling them Stealth heads but I don't think I'm going that route. I'm not sure how much they were milled down and I don't want to get into intake not matching up to the heads. I think I'm gonna get a set of 915 heads for her insteadBTW Newport 440 where ya been did you ever get hump for trans tunnel how is that car wanna sell just kidding welcome back.
What I'm disappointed in is the lack of power. I have been in 383 cars that ran better than this thing. It's in my 70 Newport with a 4-speed and has a open 3.23 gears. In first gear at the sweet spot of the rpms if you punch it it doesn't even break the tire loose. What I would like is a good 14 sec car. The engine I don't know much about it was a raffle give away engine my dad won back in 83. About 2 years ago we were building a 55 dodge truck and he decided to finally use it when we went to fire it up it just spun over like it had no compression So thinking it was no good we pulled it out and dropped another engine in it. So when I bought my Newport he gave me the engine. I pulled the heads off thinking maybe the rings were lined up or something ? At that point I didn't know what to think then I looked at the pushrods and they were like 1/2 inch longer than stock ? The engine is a 77 block it has a steel crank and what look to be stock pistons. The heads that are on it are 906s. So what I did was install a set of stock pushrods and put it in the port. It seems to run fine carries plenty of oil pressure and doesn't burn any either the idle is pretty loppy but I did put a Hughes thumper cam in it. it says their made for low compression engines. It just doesn't seem to like revving up and if I do drop the clutch to do a burnout which is very important to me lol. it seems to go into valve float very easy. I did not degree the cam but I never have I have put plenty of cams in and built a few engine I'm not a master mechanic but pretty sure everything is install correctly. At this point I just not sure what to do next. That's why I wanted to put some kind of closed chamber heads on it hoping that would help. If you need any other info just ask cause I'm at a lost with it. thanks again for any help with itThe two best answers thus far IMO:
And:
"But the main thing is that you seem to be at the point, with cams and heads, and other stuff, that you should stop and think about what you're trying to put together, rather than throwing parts at it. Why don't you give us all the big picture: What parts, what goal, what budget? The guys on this forum are pretty knowledgeable, and can provide a lot of guidance with some more information."
There is a lot more misinformation than information floating around on the web. My approach would start with why are you disappointed? What is it not doing for you? What car is it in? What has been done already? There are a few mods that are not bank brakers that will give power, mileage, and driveability but we need to know what issues you're having.
Yeah it was all even but low like 120 / 123 I wonder if the springs are shot this engine sat over 30 years with way too long pushrods in it I was thinking about it last night maybe that's why it seems to valve float so easily when at high rpm ? I have no tach in her so not real sure what it is revving at when this happensHave you put a compression gauge on it? It's not the same as measuring and calculating compression ratio, but it will give you some info without pulling the heads.
It's a 750 afb I had the same carb on my Doba and it ran great. But that something I'll check when I pull her back out. I don't know what to do I got my tax return burning a hole in my pocket lol maybe I'll just put my 4.56 gears in her and buy some NOS. That will wake her up or blow her up haha.120 is not that bad you can run crap gas. I have one of those Hughes thumper cams in my challenger I'm not that impressed with it either but it does have great vacuum. You need to find out how far off your timing mark is sounds like you have a timing or fuel problem, my Challenger acted that way it has holes in pick up tube in the tank this problem has slowly gotten worse in the last few years. Also what kind of carb are the plates opening all the way, I know that sounds stupid but I did this with an eddy afb style primaries only opening like 3/4-7/8 making secondaries not even open that far and the counterwieghts hardly opening seemed like forever just to hit 5000 in second, I felt like a idiot for this but when fixed really woke up just some suggestions.
