I thought my old Seville was tight until I saw this one....You wouldn't be saying that if you've ever been under the dash of an Esprit.
WTF have we been saying?One thing for sure... this car has the unfriendliest, tightest, most crowded under dash area I’ve ever worked on....
The owners manual and the data book said the 1978 NYB is the most mechanic friendly dash Chrysler ever made. Lol
So you pressed the brake pedal, the map light came on, and the radio went off and it wasn't just a bad fuse?! Shocker!Fuse blown again....
Found my problem....Brake light circuit wires were run around the very top of the brake pedal for some reason. Had worn through the insulation and was grounding out the circuit and blowing the fuse. Maybe what is causing the cruise not to work. Why they wrapped the wires around the pedal, I’ll never know. I pulled it loose and put some tape around it to hold it but I need to go in and properly sort it. One thing for sure... this car has the unfriendliest, tightest, most crowded under dash area I’ve ever worked on....
