Friday I had an issue pop up in the 72 Monaco wagon. Was accelerating from a corner at normal operating temperatures when I heard a slight chirping noise. Lasted maybe 5 seconds at the most. First thing that popped into my head was that it sounded like maybe the water pump bearing was beginning to go out. Then a minute later I began to get a burning wire electrical smell. Immediately I pulled over and turned off the engine. As I did, a decent sized cloud of smoke came out of the cowl. I released the hood mechanism, ran around the front, lifted the hood to see the AC clutch sizzling and smoking. There was some stinky black goop dripping from the end plate. I don't think there was a real electrical wire issue/fire, as the smoke coming off the clutch had a terrible acrid smell.
I let it sit for a few minutes thinking about what I might be. After a bit, for good measure I unplugged the wire going to the clutch and restarted the engine. All seemed normal, no more smoke or sounds. I drove another 10 miles home without a problem.
At the time this happened, there was not a charge in the AC system, nor did I have the fan or AC system in the "ON" position. Although, a couple days beforehand, and 50 miles ago, I had attempted to recharge the AC system with 134 after installing a brand new drier. For reasons that I had not yet resolved, the system didn't seem to work. So I vented it again in the preparation of installing a new evaporator.
Not sure if fiddling with things would have caused this issue. Nor do I even understand what the problem is yet. There doesn't seem to be any slop or play as if there is a bad bearing.
Does anyone have any advice or ever had a similar experience? I'm going to go flip through the FSM but merely thought I'd ask first.
Paul
Paul
