So friends, I recently got the linkage for my Auto Pilot, ( mine was missing ) and attached it. For my '65 Imperial Crown at least, the connection at the Auto Pilot ( AP ) is at the lower arm of the spring coil, what the FSM call's the "exterior arm". Which apparently is not where it usually connects, even the FSM show the connection at the upper arm by the stud. SO as many of you know the linkage runs from the AP spring dial, down to the gas pedal pivot arm ( not sure of the proper names for these 2 connection points, but I figure you know what's what ).
On my car the pivot arm PULLS back, when you press on the gas pedal. So with the AP linkage being there, when I push on the gas pedal it pulls back on the pivot arm, which pulls the linkage, that then pulls the spring dial in a clockwise-manor. This direction compresses the spring, so naturally there's resistance because pressing on the gas pedal is ultimately pulling against the spring. What I'm trying to figure out is, with the car off, is it normal to feel that added resistance of the linkage pulling and compressing the AP spring in the gas pedal, when I press down? Before the linkage was connected, I'm used to being able to quickly tap the gas pedal to the floor w/out resistance ( on occasion ) and close the choke for doing cold starts. Now with the linkage there, the gas pedal travels just an inch, then I feel the resistance. I could probably apply more pressure to move it further past the resistance, but I stopped when I felt the resistance because I wasn't sure if it was right, and didn't want to damage anything by forcing it further. All this is with the car NOT running. Anyway, I've been told from a reputable forum member here, ( Ross Wooldridge) that he didn't think that was right, that the gas pedal should not be hindered, even w/ the linkage. He said I should have no higher than normal resistance at the gas pedal with the car off, ...But he was basing that on his car and how it behaves for him ... which is a '66 Chrysler ( not sure of the make ).
So I say all that in the hope that someone with an Imperial like mine, with a working Auto Pilot, can clear things up about what is to be expected in terms of the gas pedal and what amount ( if any ) of extra resistance should one experience? ...with the car not running. Frankly, with how this all moves and connects, I can't see how there wouldn't be any extra resistance on the gas pedal ...but I'm new to all this so, what do I know Anyway if somebody can shed some light on this for me, and I would appreciate anything you can add.
Thanks,
R
Thanks,
R
